linking speccy (+3) to PC
I want to load games in to the speccy, I can do the soundcard playing into the speccy thing, but, is there a more advanced way?
i've had a look for info on RS232 connections, etc, but the only 'easy' software i can dig up is Linux based, i'm an XP junkie
this'll be a nice interim till i build the HDD interface
Post edited by bleugh on
Phoenix (of RA and Papaya Labs) did write RawwOS which gave you a high-speed RS232 connection - not sure if it's still available. If I recall it had a server running on the PC which sent the requested files.
In theory you should be able to use something like HyperTerminal to do the comms from the PC side.
I think there are a couple of terminal progs in the archive for the speccy, but of course these will take up memory,
I'm no expert, but you could possibly write a program to take the data from rs323, and write to empty 3" disks, if you have any blank disks, but if you loaded the games straight to memory you wouldnt be able to use the full memory (as the transfer prog would need some), and some games may need to be hacked to run from different locations
