If an Atari can do it...
Ok, after the "If a C64 can do it" thread I started checking out a few demos on other 8 bits and I just had to pass this one on. It's for the Atari and requires 320K but it's pretty cool. Some of the others on that site are also pretty impressive.
http://atarimania.com/detail_soft.php?MENU=8&TYPE_CODE=D&SOFT_ID=11402
Sorry, couldn't find it on youtube.
Post edited by JamesD on
http://en.wikipedia.org/wiki/Atari_DOS
Make sure you have the emulator configured for enough RAM.
Have to say though, that is very impressive when you consider the hardware being used. Is there anything on the spectrum that gets close to this??
http://www.strotmann.de/twiki/bin/view/APG/DosAtariFour#The_OPEN_command
Is this for one of the computer models, rather than consoley?
The other demo, by the same guy, looks quite good too.
... does look a nice demo, they got good colours the Atari`s from the look of it !
http://www.youtube.com/watch?v=qiNJW0k2fVo
Link for demo at :-
http://atarimania.com/detail_soft.php...
emulator at :-
http://idiology.com/Atari.aspx
Very bottom right of page, little text for download link, plus instructions there :)
basically, put emulator where you want it, put Rom images in, selct them for the OS-B (don`t get one for A), XL/XE, 5200 and lower down for Basic Rom, reset (Shift + F5)
Select machine type XL/XE, Memory Size 320 (I chose Compy),
Attach disk 1 into drive 1,
and reset, need to insert disk 2 halfway thru, think it`s Alt and B... erm
http://numen.scene.pl/
And I suggest you check the download page. Some interesting stuff there!
:D
