technical question
how do i open a command promt in a directory?
im wanting to patch a game, and the instructions say i should open a command promt in the same directory as the rom and the patch, but i only know how to open one through the start button.
more info
im doing it on a PC, in windows 2000 professional.
thanks
more info
thanks
Post edited by mile on
So you go to start /run and type in CMD and enter
Then you just go to the directory, eg
cd \ to get to the root
dir /w and enter to list all the folders
probably
cd program files
Find the folder you need, eg...
cd porn
and then do the command they tell you to there ? Normally you then type in a command (which they tell you) and the patch then overwrites or amends the exe file ??
'Think' this is what you mean ?
cd C:\Directory1\Directory2\
(i think you may need to surround the path with "..." if there are spaces in the directory names, and swap the Directory1 etc... with the correct folders for yourself)
there's also a tool on the Microsoft website which adds "Open Command Prompt Here" to the right click menu in explorer, handy, but it may be XP only.
Edit: what he said ^^^
pat on your backs.
... 5 mins after...
Got it back here. I'd use method #5. Don't ask why, as I don't really know.
Regards,
Marcelo
