Stopping autostart/autorun and entering POKEs
edited April 2007 in Games
Hi,
I want to enter some POKEs into a game on my ZX Spectrum, but whenever
i do a LOAD "", my games always autorun. Is there any way I can get
the program to just load into memory so I can POKE and then RUN the
program?
Post edited by Gizmoguy on
  • RNDRND
    edited April 2007
    try MERGE "" that will load the first block and stop.
    Facebook @nick.swarfega Twitter: @sw4rfega
  • edited April 2007
    Which emulator are you using? The instructions differ based on the emu.
    (Oops! You are not using an emu(???))
  • RNDRND
    pelts skarpo with a haggis.
    edited April 2007
    /me pelts skarpo with a haggis.
  • edited April 2007
    RND wrote: »
    I actually do like haggis*, so thank ye very much!
    Skarpo
    *Well, it depends on how it's prepared.
  • edited April 2007
    RND wrote: »
    I tried a MERGE "" but as it loads the first, and only the first, thing, it only loaded the loader, and I don't know what the game itself is called. Any ideas?
  • RNDRND
    edited April 2007
    well after the merge has stopped enter your pokes, then type RUN and start the tape, the game should continue.
    skarpo: I love haggis and gravy!
  • edited April 2007
    That won't work the game will overide the pokes when the new data is loaded in
    you really need to give us the name of the game before we can help further
  • edited April 2007
    Can you give us an example game so that we can guide you better?
    Some games have a really simple loader like this:
    10 LOAD""SCREEN$
    20 LOAD""CODE
    30 RANDOMIZE USR xxxxx
    where you'd put your POKEs in at line 25. Others may have protected loaders or autorun - Manic Miner is one example (I think).
    If you look at some cheats sections of magazines like CRASH and SU they have complete replacement loaders that you have to type in to be able to POKE your game.
  • edited April 2007
    I tried what you suggested with 'Skateboard Construction System', but it didn't work. It began loading and then it lokked like it had reset and had the Amstrad copyright notice in the bottom left hand corner. Do I need a 'Multiface' or something like that?
  • edited April 2007
    Some game loaders are protected so you can't use MERGE "" on them.
  • edited April 2007
    If I used a Multiface, would I be able to enter POKEs with that? Would it solve my problem?
  • edited April 2007
    The following program will give infinite lives in the demo game Kickturn:
    10 LET t=0
    20 FOR x=32768 TO 32811
    30 READ y
    40 POKE x,y
    50 LET t=t+y
    60 NEXT x
    70 IF t<>5212 THEN PRINT "Error in data" : STOP
    80 CLEAR 24499 : RANDOMIZE USR 32768
    90 DATA 221,33,203,92,17,226
    100 DATA 0,62,255,55,205,86,5
    110 DATA 48,241,62,201,50,46
    120 DATA 93,205,23,93,33,37
    130 DATA 128,17,158,253,1,7,0
    140 DATA 237,176,195,112,253
    150 DATA 175,50,156,242,195
    160 DATA 28,237
    (Poke by Gerard Sweeney taken from The Tipshop, I just wrote the loader)
    However another way of hacking it would be to use the SAVE WHOLE option on the menu which is used to create a stand-alone game; this saves the game code without a custom loader so you can load it in as recommended (ie. CLEAR 24499 : LOAD "" CODE : RANDOMIZE USR 60700) but you can also include the poke if you wish (ie. CLEAR 24499 : LOAD "" CODE : POKE 62108,0 : RANDOMIZE USR 60700).
  • edited April 2007
    Crisis wrote: »
    Hi,
    what is the Game?
    Well anyway to know the names of the parts following the loader you can use
    VERIFY "_" or VERIFY"***"
    use a name probably not used in the list.
    so "Commander" might use "Com" in the name, so dont use "Verify "com"
    Verify wont load any thing into yr spectrum but it will let pass al prog blocks until it found the right block.
    meanwhile al names are printed on your screen including if its code or not ( Prog: Bytes:)
    you can search on wos in the archive for an header reader program.
    then you have exact info.
    I wrote one buts not in wos since i never realy finished it.
    maybe i will do.
    It's not just one game, I was kind of looking for something 'universal'. I'm trying the VERIFY "_" now (thanks for that, I didn't think of that :lol: ). BTW, do I need a Multiface to use POKEs?
  • edited April 2007
    The VERIFY "_" returned this:
    Skate D:
    Program: ??????????
    Upon trying a LOAD "??????????" it didn't find it/list it or load it.
  • edited April 2007
    The main way around your problem IS a multiface.
    The majority of spectrum games you are likely to want to play (and cheat) either have custom loaders or fancy ways of compressing themselves.
    This means that the spectrum loads the game in a compressed or encrypted form and when the spectrum executes the machine code the first part of the code unpacks the game to its final (workable) state.
    Thats why even loading the code and then poking will fail in a lot of games (because although the games loaded - its not unpacked yet).
    For a complete solution you could get a multiface - so you can stop and alter the code while it is running.
    Or you could add the poke to the game you want to cheat using an emulator. You can then save this snapshot back to tape using a program like Hypraloader. (I'm showing my age - I'm sure there is a newer program that will do this)
