zombie zombie question
hello
i am trying to map this game(nearly all done)but what of the talk of a second city.i have entered the cheats for acessing the 2nd city but what i get when i play the game is the 1st city but a different view,is this supposed to be the 2nd city???.thank you
colin
colin
Post edited by ladderman on
I can get it to appear when I try this method.
From the tip-shop
"To get to the other one, you must load the game as usual, go to the main menu without playing it, then press P followed by CAPS, and an input prompt will appear at the bottom of the screen. Enter (in upper case) SPACEMAN, then press ENTER. In lower case type in xchg and you are ready to do battle with another city-full of the undead"
This SOMETIMES doesn't work 1st time ( or second for that matter ) so keep trying.
You will tell instantly that the city has changed. Where the old city had the letters (c)AS (Angela Sutherland) it now says SPACEMAN WAS HERE.. and the rest of the city is very spartan compared to the main one.
Just to show it works ;)
http://i87.photobucket.com/albums/k158/spaceman70_2006/zombiealt.jpg
PS.. If you have real probs.. PM me your email and I will send you a snapshot i saved :)
