Manic Miner for the Gameboy Advance.
I saw a modern remake of Manic Miner for the Gameboy advanced today.
It's basically the same give but with modern graphics.
I never knew this existed, has any one here played it, is it worth my buying??
Andrew.
Andrew.
It doesn't save your scores or anything, and it is very subtly different but does have the original levels and some new ones.
Why not download it and try it out on an emulator first?
There is the classic Manic Miner and then the 'updated' one. The classic is pretty much exact copy of the speccy miner, the new one is different rooms but looks similar.
Must admit, it grew on me, but only once I turned off the background layer... can`t remember if I did it using emulator, or if the game gives you the option.
Oh, and there was a thread about it a couple of years ago, I think started by zxbeccy, so that should tell you :)
However, I dont get the Paul McKenna referece please explain someone I'm curious if a little miss informed.
Andrew.
Andrew.
It's not bad but I wouldn't buy it, in fact I went off on it on the MM/JSW Yahoo Group when I was drunk one time.
However I read what I'd said about it, and thought I was a bit harsh, so I played it a little more, and a little longer all bad. So I went back online and retracted my ranting.
Some of the new rooms will give you a challenge for about an extra 10 mins, and you get passwords every few screens so you don't have to go from the start every time.
