Brand new 3.5 inch floppy drive with a Disciple Interface
Hi folks, I just acquired a disciple interface and have bought some brand new "pc" floppy drives to use with/on it but cant get them to work. I found an ascii drawing on this site of the ribbon modification which i think i followed properly but wont work. If i plug it in 1 way the spectrum will say no disk in drive and the light will stay on permanently, if i plug it in the other way (upside down) the drive will try to access the disk when prompted but no light on and it just waits forever/u have to press break etc. Is this actualy possible? or am i simply getting the wiring wrong.
Also what is the difference between HD and DD floppies? I only have HD floppies, can i force it to use these? The floppies work fine in this drive when connected to my pc by the way.
ZX-MAD
ZX-MAD
Post edited by ZX-MAD on
DD = Double Density - 1.0Mb unformatted, 720k formatted
I *think* you can use HD discs with DD drives. IIRC there is an extra hole in the case on the discs so the drive can determine the format. You may have to cover this hole with sellotape so the drive thinks it is a DD disc.
You can try covering the HD detection hole in the disks, but this can cause problems especially if you later need to use a different disk drive.
You could always get some DD disks from me :-)
www.rwapsoftware.co.uk
www.sellmyretro.com
Ive tried covering the hole in the disks with the drive in my pc and this just makes the drive unable to read the disks at all??? Is that normal. I read somewhere that formatted HD disks will never be able to be read in DD mode, is this maybe why they aint working? Im not convinced its just the disks that arent simply working as the drive just spins forever when i try to access it instead of reporting no data/disk etc. I have the DS1 pad soldered when the drive is in my pc and the DS0 pad soldered when its connected to the disciple.
ZX-MAD
HD floppy disk is like using CrO2 tape on "normal" tape deck, is don't work well.
K heres the ribbon i made up you can see the wire connecting pin 1 and 2 :-
and heres the jumper settings/solder pads on my new drive :-
Erm, try removing the wire.
i'll try and dig out the cable twist they're linked from these forums somewhere.
http://www.worldofspectrum.org/forums/showthread.php?t=19630&highlight=plusd+cable
it shows how to rewire a standard floppy cable so that the twists do the drive select. Drive 0 goes at the very end of the cable after wires 10,11, 12 (I think) are swapped to run in the sequence ...6.7.8.9.12.11.10.13.14...
That's all that's required, I think you may be confusing the disciple by asking for Drive 0 but only have drive 1 (the second drive, attached.
Remove the jumper wire you added.
Give it a whirl.
+D/Disciple
Twist 12,11,10
Drive 1
Twist 10,11,12 --- Drive 2
The first twist is unnecessary, without the first twist:
+D/Disciple
Drive 2
Twist 12,11,10 --- Drive 1
ie, flat cable to drive 2 then twist 10,11,12 to drive 1.
Don't worry if you don't have a drive 2.
Oh look Drive 1 Drive 2, Drive 0, Drive 1 just to confuse.
How about Drive A, Drive B
You know what I'm getting at right?
Not easy I know, but I do have bare DD disk units too which have jumpers for selecting master / slave!
Rich
www.sellmyretro.com
As you can see it does work and it works a treat. Altho you must cover up the hole opposite the read/write hole on a HD floppy disk or it wont be able to use it.
Thanks for he help and advice guys this is one superb site and forum.
You shuld be able to add a seond floppy straight to the cable.
DD Disks come up on ebay in big unused boxes every so often, worth getting as they should be more reliable than taped HD ones, but if you keep backups then you should be find.
There are utilities like samdisk which allow you to create disks from images and read real disks back to the PC. I'm assuming that the Disciple ahas the same format as the PlusD.
I used HD discs on an Amiga with no problems. Maybe it was because I used "disc copy" tools to copy an entire disc, rather than file based i/o on the disc? In some quarters using HD instead of DD was reccommended.
Nobody can tell me that I cannot use HD Disks. In fact I heard that when some producers still produced DD-Disks while everybody used more and more hard disks, they just did make the same disk but without hole... DD - Disks they could sell for higher price. However, nobody recognized because it simply works. I have Opus since more than 20 years and also a +D for some time. As I have also a MB02 using HD-Disks, I just did buy HD Disks for all systems and it still works, while many DD-disks from old time are now corrupted.
Read about our disk-magazine on www.sintech-shop.de/home/spectrum-user-club.html
Regards
Thomas
HD disks work fine in DD drives I'm using them now with my discovery on my 48k and my plus 3 drive b and have in past on my amigas without any problems just put tape over the HD hole
ZX-mad I would go with a gotek with flashfloppy far easier I do the same with the discovery and my plus 3
As stated elsewhere and hinted at up thread, the magnetic material on HD and DD disks is different. So by using a HD disk in a DD drive (or in a HD drive operating as a DD drive) you are working outside the specification of the disk and of the drive.
Elsewhere, one factor appeared to be significant. That is HD disks that had not been previously formatted (or disks that had been erased by a bulk eraser) were found to be more reliable compared to ready formatted disks.
On the other hand, it's perfectly okay to use DD disks in a HD drive that is capable of operating in DD mode :-)
