MAME (PC based) Question
edited April 2008 in Chit chat
I want a version of MAME for Win XP / Pentium 4 that supports the hi score save - I seem to remember, from a forum somewhere, that after a certain version, MAME no longer supported the hi scores, because real arcade machines would not do so when unplugged (bloody purists). Correct me if I am wrong.
So, what is the best version of MAME that last supported hi scores and what ROM set would it use?
Thanks folks.
Post edited by mrmessy on
  • ZupZup
    edited April 2008
    I don't know if newer versions of MAME don't support high scores, but some games (Tetris) store scores in NVRAM (so it's stored in nvram files).
    There was a file (hiscore.dat) that enabled to save scores in many games. The last version can be found here.
    And remember: if you enable cheats, no hi scores will be saved.
    I was there, too
    An' you know what they said?
    Well, some of it was true!
  • edited April 2008
    Mame Plus! supports hiscores and a few other things like auto volume leveling for games that are to loud/quiet. This is the one I use.
    You will also need this lot too:
    Latest hiscore.dat
    Latest cheat.dat
    Latest history.dat
    Just put those .dat's in the main Mame directory. As for a romset, UTorrent is your friend... ;)
  • edited April 2008
    The official MAME build stopped supporting hiscore.dat around version .120. I have .106 as my "main" build and that does save high scores.
  • edited April 2008
    Cheers folks.
  • edited April 2008
    Or use one that supports save states.
  • edited April 2008
    Are you guy's using a full rom set and not downloading individual game roms then? I'm desperate to get hold of the Carnevil chd but can only find it in 50+gig torrent downloads. I only want Carnevil so that's no good to me :(
  • edited April 2008
    Well click on one of the FULL .chd sets and 'select' the game you want when it appears in UTorrent and before you select ok to start downloading. Easy! ;)
    Edit: You better have a kick ass PC to run it too. Most of these .chd games have very high spec requirements.
