Need help with Sirwood.
edited May 2008 in Games
Am trying to get Opera Soft's Sirwood to work. Or rather I get it to work ... I think ... but what do I do on the first screen with the guy playing the music and the frowning tree and all that?
Post edited by ZnorXman on
  • edited May 2008
    According to the instructions the keys are the usual QAOP and SPACE but that initial screen doesn't allow me to do anything ... no keys work and I don't have a joystick right now to test to see if it's really a joystick-only game.
    Any help apprecieateatrataeededeadaedddddeeddd.
  • edited May 2008
    That game has many parts, the first one you are loading is a demo, you have to reset the spectrum and leave tape running from that moment to load the second part which is the first playable stage.
    Hope it helps ;)
  • edited May 2008
    Thanks Ivanzx, I knew there had to be a trick to it!
  • edited May 2008
    Man ... I've been looking forward to playing this game for a few weeks now and am saddened that it's a bit of a disappointment :-(
    It's a tad on the slow side when it comes to responsiveness, in particular when jumping. I think it's because it's attribute spaced jumps/movement so it's a bit jerky in movement.
    Sad, as this is a good looking little game ... *sigh*
  • edited May 2008
    Yes, its a little bit dissapointing game, I have the original cassette and It was also quite hard to load, so I didnt play it much back in the day!
    Cheers
