Chip Tunes/Electronica
edited June 2008 in Sinclair Miscellaneous
Cheveron has done some ZX remixes.
Post edited by chev on
  • edited May 2008
    Nice, very nice indeed!
    Could you share more details on what instruments you used, how you saved it (real-time or sequence), etc?
    Thanks.
  • edited May 2008
    It does, thanks! Excellent work. I didn't know you had so much talent. :o
    Keep up the good work.
  • edited June 2008
    Nice work there Andrew.
    I use a tool called VAZ Modular 3.6 by STL.
    Its basically audio modelling software where you build your own synth from Moog-esque components and then control it and play it by midi.
    Its UI has a more realistic visual metaphor than most analogue modelling software, i.e. Reactor on the Mac. I found the learning curve of Reactor huge, but the learning curve of Vaz alsmost instant.
