X-box questions part 7
edited March 2009 in Chit chat
has anyone linked xbox 360's up before?
i have an elite model, and want to connect it to another elite model. do i need to buy a special cable or is there one in the box?
also do we need two copies of a game to play?
Post edited by mile on
  • edited February 2009
    I take it you mean XBox 360s? Sorry mate, I don't know, but you could try the 360 forums at:
    xbox-scene.com
    but look through their FAQs first, as this question might already have been answered.
    As always, please post the answer here if you find it, in case anyone else ever needs to know.
    I've never done it myself, but I've just had a wee look on the 'net and found this: http://support.microsoft.com/kb/910583.
    GreenCard wrote: »
    cheers green. It basically just tells me to read the manual, which i was going to do. but people experiences are always more helpful. :)
    It does tell you what cables you want and stuff too, erm, and stuff... jeeeeeeeez!! :-D
    GreenCard wrote: »
    yeah it did say what cable i needed, it didn't tell me if i already had it though. :-D
    When u say "connect" u mean to be able to play local multiplayer games?
    Just a simple crossover will do I think...
    Pyjamarama wrote: »
    yes, probably.
    whats a crossover?
    I mean a crossover ethernet cable (but u can try a regular ethernet cable because I have read that the 360 is smart enough to distinguish them and act accordingly)
    Now,if u want to have Live as well,just hook me both into a hub with regulat etherner cables (an give manual IPs to avoid the DHCP trouble).
    Pyjamarama wrote: »
    If that is the case, then there should be one in the box. There, mile... happy now?! :grin:
    I believe the ethernet cable that comes with the Elite/Pro console is all you need to link the 2 Xbox 360's together. The xbox 360's do the crossover automatically or something so you don't need ethernet hubs or special system link cables.
    You will need 2 copies of the game too and 2 TV's too I suppose. :)
    cheers guys for the help. shame you need two copies of the game, we want to play left 4 dead, i might rent a copy for that day or something.
    I once played 4 player Halo3 on 4 linked 360's at the R.C.M convention. Probably the first time I played it with absloute zero lag.
    Yeah...it's just a case of sticking the Ethernet you get with it between the consoles and firing the games up on both....My cousin and I did it with Halo 3 when I got my Xbox..
  • edited March 2009
    Does anyone here know if it's possible to hook a 360 up to a PC (to transfer stuff onto the 360's HD) without having to buy the connectivity kit?
  • edited March 2009
    GreenCard wrote: »
    can't you just use the ethernet cable? you have to downlaod something onto your PC though first.
  • edited March 2009
    I have no idea. I've just downloaded Xplorer, so I'll fire it up and give it a bash.
    EDIT: Ok, so I've tried it and no joy... but then I have no idea what I'm doing!! Yes, I am useless!!
