Wacky Races
edited June 2009 in MIA/STP/SDP
The tzx file appears to need some stop the tape blocks.
Post edited by Fraser on
  • edited May 2009
    Never noticed that when using it on an emulator before, but because I like a challenge, I'm going to try and make a TZX from my tape of it..
  • edited May 2009
    Sides 1 and 2 have been merged into one. There needs to be a stop the tape block after each level.
  • edited May 2009
    OK - thanks for pointing that out.
  • edited June 2009
    I've got it and will take a look.
    Steve
  • edited June 2009
    @Fraser,
    Looks like you've got an old tzx file...
    I have two .tzx files (Dated 6th March 2005), one for each side of the tape... The 2nd tzx file has the stop blocks in between each level....
    Try re-downloading the game from the tzx vault or WoS.
    Steve
