TV output from original +2
I've modified my 48K Spectrum to output composite, and I have it working here in Japan on my old monitor (X68000). Hopefully my parents will bring over my +2 in a few weeks when they visit. I assume that the +2 outputs composite in the same way and can therefore connect it in the same way. Is this correct?
Post edited by MagicKnight on
No. The spectrum +2 ( as same as +128K, +2A,+3) includes a sound carrier. You don't have composite signal en the modulator.
The spectrum +128K and +2 have composite signal in the RGB connector ( not the +2A/+3). The composite signal is in pin number 1.
This web explain very good all this things
http://www.fruitcake.plus.com/index.html
Bye
Jos? Leandro
PC-9801 etc.)
The machine does have an earphone plug so I could use exteral speakers, is that right? It's a long time since I looked at one properly.
Other than that, I don't think I have a chance of connecting it up. Maybe I'll just stick with the 48K model.
If this noise happens and bothers you, there's a simple way to eliminate it: locate capacitor C24 in your Spectrum PCB (a very small 33pf capacitor) and remove it. This is the responsible of mixing the video and audio information. If you remove it, you won't be able to hear any sound when using the RF output. The sound output from the 3,5 jack is not altered in any way.
Also, be very carefull when doing the composite mod. I don't know which composite mod version you have used, but you must take into account that the TEA2000 is a very delicate IC, and may be easily destroyed if, for instance, the composite input of your monitor has not the GND connected to the main's ground. If possible, do the composite mod that uses a BC337, a 75 ohm resistor, and a capacitor.
funnily enough I was just poking around inside my +3 the other day. a while ago I'd done the composite mod on (building the buffer amp, and hooking it up to the raw output from the tea2000) but it always had noise on the video signal (and elsewhere on the board actually) in the end I tracked it down to the oscillator and FM modulator creating the sound subcarrier that was no longer connected to anything. I've now removed all the sound modulation circuitry entirely as it was just causing trouble.
