TR-DOS on Spectrum +3: it works now.
Hi there.
I found this interface for Atari ST long time ago but now I noticed something interesting.
The interface is for people who has dead floppy-drives on their Atari ST o Amiga 500.
You have to remove oiginal drive and connect instead the interface. It takes loads images from PC computer (MSA, ST, ADZ, DMS, ADF and others).
Last times a friend of mine point me that the interface has also TR-DOS on-board.
It can be connected to ZX Spectum +3.
Loads files: TRD, SCL (but also DSK and Extended DSK).
You can find infos here:
http://hxc2001.free.fr/floppy_drive_emulator/index.html (the table)
Seems like you can get it here: http://torlus.com/floppy/index.php?en
PS: I'm not sure if +2A/B has somewhere on the mainboard any diskdrive connectors, inside.
Post edited by Mister Beep on
ZX Spectrum 48K BEEPER Music:
This is only FLOPPY DRIVE emulator. But for work with TRDOS on +3 you need connect real betadisc interface to system bus and to FDD cable connect this emulator. BETADISC must be modified for correct work with +3:
http://translate.google.com/translate?hl=cs&sl=ru&tl=en&u=http%3A%2F%2Fzx.pk.ru%2Fshowpost.php%3Fp%3D212164%26postcount%3D13
That said, if someone made a BetaDisk or BetaDisk kit that I could plug into my +2A I would buy it in a second.
