Matthew Smith vs Jonathan Cauldwell...
In a minor development during the last weeks of 2009, Mr Cauldwell released Jet Set Willy 16K, which can be found here:
http://www.rapidshare.com/files/322687515/JSW.tap
Regards,
Shaun.
Regards,
Shaun.
Post edited by Shaun.Bebbington on
Yep it is....even though it's bugged and you can't finish it, how ironic :D
When you say 'more cut down', what do you mean specifically? Less locations, less sprites, or both?
Edit - there aren't any ropes, and the whole of the roof, from Nomen Luni onwards, is inaccessible. You can only get as high as 'Under the Roof' and 'The Attic'. I also wasn't able to walk off the left of the 'Tool Shed', so presumably the beach and yacht aren't there. Horizontally moving sprites don't have different animations for going left/right. I'm not sure if Willy has been redesigned or if there's some sort of compression going on with his sprite. But there must be some really impressive data compression going on to get all that room data in.
The movement of both Willy and the enemies aren't terribly good though. It seems very choppy.
It could be nice to see the source.
Perhaps it could be added to the WoS archives???
Regards,
Shaun.
Awesome! Thanks! :smile:
F6
Sit still then!
Ha ha ha very good !
I'm wondering if that should go in my sig...
Regards,
Shaun.
Wow! I feel almost famous! :)
I'll be able to say to all my friend(s): "Hey, I know someone... well know OF someone... who has an email address (that might even be current) of none other than Matthew Smith!"
And my only (alleged) friend will say, "Matthew who?" ;)
I've always wanted to be someone... In retrospect, I think I should've been more specific...
Brilliant :)
Unfortunately right now our servers are overloaded and we have no more download slots left for non-members. Of course you can also try again later.
it seems to get worse, wasn't to bad when JC first started to use it
Nah. As of now, the response you'll get is "What, the new Doctor Who? Awesome!"
Gah! There goes my evening of trying to RZX it, no point now :cry:
Sorted! Cheers muchly :)
will tell Matty!
www.real-sense.com/chris/zx/JSW.tap
