it should say on the front of the magazine the issue no, alternatively, if you goto the archive section on the main WOS web site, scroll to the bottom and you will see magazines, select c+vg, you can look up both issue 104 & 107 there and you will see the issues i'm after.
Regards,
Mike.
cheers.
Regards,
Mike.
