Using a Trust Predator joystick with ZXSpin
Greetings everyone!
I need some help, I want to use a Trust Predator joystick or keypad with ZX Spin, how can I do it?
Thanks!
Thanks!
Post edited by Danae's Fan #1 on
Alternately, if any game uses the cursor keys you can set the joystick to emulate that or even define your set (the User Defined option).
You are now set to use the joystick within any game. Simply start the game, select the relevant joystick in the game's main menu and you're off!
HTH.
