Hypersports, help!
edited September 2010 in Games
I suddenly felt like playing this great game, so I loaded in my +2A, but...I cant get past the 3rd level!
The thing is that I dont remember when I had to press space or right and left just after the first jump. I have tried many combinations, but none seems to work.
So anyone remembers after when you press space to jump, what do you exactly have to do?
Thanks!
Post edited by Ivanzx on
    level 3 is spring / vault (my fav level I guess)
    speed up.. left right
    jump on the board *fire*.... you go on the vault then .. when your straight again hit fire / jump
    if you don't hit fire when doing handstand , you'll fall / fault
    left / right to do somersaults.. BUT try to land on your feet or time it so you do :)
    http://www.youtube.com/watch?v=QV4WtSXzL4Q
    2:26 in
  • edited September 2010
    And in the weight lifting bit at the end, the mighty JOF wins!
    fog wrote: »
    2:26 in
    Thanks mate, I passed it!! I remember when I was a kid I used to play this game a lot, and we never managed to get past it! but we still tried a lot of times...ahh the good Joffa :)
    I've managed 9.99 a few times on the 'vault' level before. Im guessing that's the max you can score. love the bouncy along the ground head thing he does if you land wrong sometimes!
    I used to be hit / miss with tripple jump and weight lifting..
    but c64 version will always have the edge solely for galway's version of the vangelis tune..
    fog wrote: »
    Im convinced the heaviest weight is impossible. the amount of time you get is nowhere near enough to build up any sort of 'rhythm'. - cos it's not a case of flat-out button bashing on that event (even though that does seem to also work on the lightest weights)
    there is an "auto waggle" thing on retrospec.. so that'd give the definitive answer I guess :)
    dunno if you can adjust it to "human" mode.hehe
    WELCOME TO TWENTY YEARS AGO (or whatever number of years it was)
    i was EXACTLY the same ..... stupid vault!!!
    You don't have to waggle to run. Just fire to start auto running, fire to jump. You only waggle to do the somersaults.
    the faster you run.. the further along the vault you get.. the more height / somersaults you do :)
    No, as far as I can recall Frank is right... once you start, it takes you up to full running speed automatically, no waggling required. It's the timing of the springboard that determines how far you get along the vault.
    You do need to waggle on the run-up for the triple jump, though.
    fog wrote: »
    i dont know what you've been smoking!?:-P
    nothing.. I gave up june , the year before last (finally :) )
    but it's not the same with all versions? that surprises me it doesn't affect things.
    edit : 64 one doesn't it either, I guess I was confusing with the triple jump.. but the speccy one does have the energy meter?
    fog wrote: »
    It does have the energy bar at the bottom, but it builds up automatically once you've started the run.
