128+ rgb
I have two 128k speccys which I connect to a rgb scart lead. The one when I power it up shows the first screen ok. The second one rolls on the screen and needs to be put on channel 1. The same one when Death Stalker is loaded in 128k after a few minutes it crashes. Also it has very small flashing black lines going across the screen but there is sound there. If I load Death Stalker in 48k its ok. Iv never had this happen on the other speccy. It has just had a ZTX651 added to fix the black screen which is ok now. Am I right in thinking that the rgb signal is slightly out somewhere?
