Laser turntable
edited November 2010 in Chit chat
This is one piece of equipment i would like to have,ten grand price though!,those with the cash head over to http://www.elpj.com/
Failing that some youtubers made their own ones!-
Then theres the soundwagon vinyl player,- http://www.soundwagon.jp/product.html
Post edited by JACK98 on
  • edited October 2010
    I've seen that TT before. I love vinyl but thats out of my league. Its bound sure to pack up some day and then be wasted investment due to the unavailability of parts.
    Its one reason I want a Lin Sondek someday, because they are good (if a little over rated), and have loads of spares available.
    I currently own a Systemdek IIX and Technics SL1220 Mk2a.
    You can also play (badly) your LPs with a scanner and PC. I've heard that the laser player needs the LP to be ridiculously clean. A needle will push loose dirt out of the groove. The laser will click on every speck, so you need to buy an expensive disk cleaner too.
    My Dad had a tricked up LP12 Sondek which sounded very nice. He's replaced it with something more esoteric now though.
    ill just stick with my Gemini PT 2000's
    they play backwards too :D
    I love Vinyl, but even I wouldn't get one of them, even if I could afford it. Apparently dust sounds like rifle fire, and the cleaning machine costs more than the turntable!
    I'll stick with my Technics deck.
    does it do 78rpm? :razz:
    So is the idea of the laser thingy, that it wont damage the vinyl?.
    1980-20.. wrote: »
    That and that it can aparently pull more detail off of the record.
    edited October 2010
    the lazer thing was mentioned on either gear slutz.. or a pro audio forum I'm on ages ago.. errm most of the really high end.. most people wouldn't know..
    but GS forum they get really "funny" about things..and a bit snobbish / elitist sometimes.
    mine has a reversible needle, for 78s on one side and 33/45 rpm on the other.
    And an autochanger (only it's broken)
  • edited November 2010
    guesser wrote: »
    Sounds like a Garrard. Wish I still had mine.
