Strange device, TR1?
edited December 2010 in Hardware
Browsing through ebay I came across someone selling a speccy, he'd done a video and one of the devices in it was a TR1, picture was a bit blurry so i couldnt make out anything else, anybody know what it is? apparently the tape leads are plugged into it so im assuming its some kind of copying device
Post edited by Macc on
  • edited December 2010
    Does look a bit strange.
    I don't have any audio on this machine so not sure if there's any on the video.
    I'd guess it might be some kind of noise reduction unit perhaps ? :-?
    Heres the video link, it appears at 1.20, is upside down and spider, youre not missing anything with the audio, just loading noise from his failed attempt at loading Pitfall 2!
  • jpjp
    Hello,
    I am wondering about the need for a "power supply". Otherwise I would think it could be a simple transformer (TR1) transforming the low output impedance of the player into the gigher one of the spectrums input while increasing the voltage of the signal. It would be a very cheap and simple (voltage) amplifier for the players signal.
    Greets Ingo.
