Benny Hill's Madcap Chase
Gave this a go as it appeared in the YS Daily Fix and I hadn't played it before..
Is it just me or is level 1 quite tricky? Feels as if you have to be completely flawless, the time seems a bit unforgiving if you muck up slightly.. The Crash review suggests the first couple of levels are meant to be easy.
Post edited by Morkin on
Note I did not say level.
I'll fetch my coat.
