Lerm Tape Utility C
edited April 2011 in MIA/STP/SDP
Hi folks,
These Lerm tapes are doing my head in. Through the years I've aquired lots and lots of samples of these, but never been able to make a clean TZX of most.
I've got some examples here of Sides A & B from the tape:
http://dl.dropbox.com/u/15363623/tuc1a.zip
http://dl.dropbox.com/u/15363623/tuc1b.zip
The first 4 blocks (2 header + 2 data) and they are ROM blocks and can be stored with ID.10.
There's a 1 or 0 ms pause between the blocks, but the 4th seems to need 1161ms or so to allow the loader to kickin (I think)
The rest, 6 blocks in this case have a 1 or 0ms pause and use a turbo block (ID.11).
From most Lerm tapes I've looked at they have the following timings:
Pilot Pulse = 2165 : Pilot Length = 248
Sync 0 = 667 : Sync 1 = 735
Bit 0 = 856 : Bit 1 = 1712
I'm unsure whether the Bit values should follow the rule 1 = 0 * 2 or not ?
Sometimes the Sync values are changed by the convertors to 714:714, these are wrong
of course for standard timings.
Is there any clever bod out there who can find out what the timings should be.
I also have a problem with most of them where the final small block will not decode properly and result in a checksum error in the block. I don't know why this is ?
Finally if anyone want's to make up the tones that are between some of the blocks or at the end, that would be cool, but I don't think these are needed for loading, just to fool other copiers.
Post edited by Andrew Barker on
  • edited April 2011
    I've put up a ZIP archive containing one of the blocks which often barfs in a convertor:
    http://dl.dropbox.com/u/15363623/TUC.zip
    Inside it is a WAV segment of the block, and also the tones often found on the LERM tapes.
    There's also CSW, PZX and TXT output of these.
    Finally, I've added a Side per side partially working TZXs. On Side 1 TUC works, but
    CU5 doesn't. The 3rd program is just a TYPE to identify code blocks. This isn't present on Side B. Side B contains TUC and CU5 again, but TUC doesn't work and CU5 does.
    I could of course use both sides to fix the full TZX, but the point is that I wonder why I have trouble converting these. There must be something at play. I don't know if it needs polarity, certain pause requirements or the SYNC or BIT values are wrong, or even if there's some pulses missing somewhere ?
    Any help is welcome.
    Cheers
