Magic Carpet
Please add the following "known errors" description for game Magic Carpet:
In this case, just documenting the problem should be enough. There will be no BUGFIX file for the problem above for the following reasons:
The player score is stored using only 2 bytes at addresses 29135/6. Because of this, when the score exceeds 65535 (typically after completing all levels 4 times) it overflows and restarts counting from zero. Since the current score also works as a timer limit, this may not leave enough time for the player to complete the following level, thus loosing the game.
- The bug doesn't prevent finishing the game (actually the game has to be finished multiple times before the bug appears);
- It would be too much work to change it;
- Perhaps it should not be fixed anyway since this behaviour is flawed by design (the score is not a 2 bytes integer "by accident", the programmer simply didn't think it was important to support players finishing the game several times), although it certainly deserves the "known errors" entry described above.
