I think modern versions of fuse won't read physical disks. Earlier releases depended on a library (libfdc, lib765 or libfdc765, or something like that) that allowed direct access to floppy disk controller, but that is not true anymore.
In windows, Realspectrum could read floppies, but I don't remember if it needed fdrawcmd.sys.
I was there, too
An' you know what they said?
Well, some of it was true!
I you're wanting to read +3 disks on an emulator, you'd have to hook up a 3" drive in the first place. So you might as well just dump a disk image with something like SAMDisk: http://simonowen.com/samdisk/
DIM will show you if your disks contain errors in a visual way, assuming you're dumping
data disks rather than commercial you can easily tell as all sectors will be white (grey for unused).
On windows you can use realspectrum but it's pretty clumsy.
This way, you can make an EDSK image and check it in Disk Image Manager:
http://damieng.com/creative/development/sinclair-spectrum/spin-disk-manager
http://code.google.com/p/diskimagemanager/downloads/detail?name=DiskImageManager.exe&can=1&q=
