terminator & lotr o.s.t. theme
aah - don't tell me it's not the same! 8)
(allright, allright, it's just a simle loop, not any full themed remix or whatever, but for comparation, I believe, it does the job...)
Post edited by de Vandemar Croup on
G! - That makes sense in BASIC 0:1
I cannot even find the LOTR tune that matches it in any way from my albums.
it's just that short motiff at 1:06 - 1:12, honestly - I played it bit faster as a bunch of consecutive notes and didn't bother to realistically keep the original rhytm, yup, might be a minor bug, but the tones are definitely the same (in my version and in the original theme)
I even chose similar instruments to imitate the original score, as many wouldn't notice the "theming" I believe.
in case of lotr-isengard the original score was some inches out of tune [inbetween F# - F] so this is the closest pitch to be played correctly.
it's the riff at 1:34
well, it's just tiny part of both of the themes, to be exact, but that should be obvious. and it's focused on the 6 tones in a row in both themes - so the number of notes is the same in this case.
but that reminds me I should rather excavate the original 6 consecutive notes sample from those themes first to be straight identifiable of what we are talking about.
but that would be another video - as I don't know at the moment hpw to replace youtube video for another with the same link and tags.
so I'll leave it ike this for now.
That's exactly what I was thinking. It's just too vague to draw a 100% conclusion that Howard Shore copied Brad Fiedel based on roughly four beats of a tune that sounds kinda similar.
