USB joypads
edited February 2004 in Games
ive just bought a SAITEK P2500 RUMBLE FORCE PAD for pc and its great for speccy emus because you can set each button including the d-pad to a key on your key board using the software provided with the pad. even use it as your mouse or combine the 2. this is my recomendation for us hardcore speccaholics.
Post edited by grim on
  • edited January 2004
    how much was it cos ive been wanting a gamepad to play games, cos i have a joystick but its suited better to flight sims and stuff cos you have to push it for miles to move directions lol .....ie:- its shite for games like pacman or manic miner :)
    it cost me ?25 the uk website is www.saitek.com i got it from dixons xl
    I use a Playstation controller through a USB adapter and that is pretty good. There are loads of buttons on a Playstation controller and you can map them all within most emulators.
    tell me more about this ps pad usb thingymagubbin cos i have an old ps and a few pads :)
    I'm using a Logic3 USB Intruder (plug and play). It doesn't have any analogue sticks, but it does the job on Speccy games. It cost ?4.49 from Computer World.
    Well, you plug it into your PC, plug your PS controller into the adapter and you are away (you may have to install drivers or latest version of direct X also). These adapters are pretty cheap (?6 at http://www.play-asia.com/paOS-13-71-6m-70-gt-4-14.html ) and the PS controllers are good quality.
    [ This Message was edited by: WhizzBang on 2004-01-28 00:20 ]
  • edited February 2004
    I have a psx-usb converter, a psx/n64-usb converter and now an xbox-usb pad converter which is the one I'm currently using, although as silly as it is, I usually cant be bothered and just play using the keyboard as nature intended. :)
    _________________
    10 PRINT "TCK is cool!";
    20 GO TO 10
    TCKsoft.co.uk
    My game on WOS: Time Wise
    [ This Message was edited by: caffeinekid on 2004-02-03 02:06 ]
    On 2004-02-03 02:06, caffeinekid wrote:
    I have a psx/n64-usb converter
    :) even better as i have 3 n64 pads too
    so id have 6 pads to use on the comp :)
    _________________
    On 2003-12-08 20:15, cyborg wrote:
    You're all corporate bitches if you buy a console - face it. Unless it's a Phantom - in that case you're just stupid - because even if it did exist it'd be crap
    [ This Message was edited by: mel the bell on 2004-02-03 19:34 ]
