+2 no tape loading sound problem
Hi All,
I've been a fan of WOS and this forum for a very long time but this is my first post - so be gentle please!
I have a +2 (grey) and a +2A. Both of which appear to be working fine apart from one thing - When I try to load a tape there is not sound. The tape physically runs okay, but nothing else happens - not even a change of border colour, it just stays white.
I have had a good scour of the forum and looked elsewhere but can't find anything on this specific issue.
Any help would be most welcome.
Post edited by landorb on
I did connect this working +2 tape mech to the +2A a couple of days ago to determine if the +2A had a problem with the PCB or the tape mech - the tape played, but again, no sound. I am wondering if this experiment has damaged my (previously) working +2 tape mech?
I will try the BASIC program save/verify and post the results...
Opened up and checked closely for any loose wires etc but all checked out okay. I loosend off the tape mech PCB to have a good look underneath, again all okay.
I then put it all carefully back together and now it works! :-o
The tape mech PCB seamed to be a little un-level before I took it off, so I started thinking that this perhaps had something to do with it. So I then did the same thing with the +2A and guess what? It worked!
Thanks for the input guys!
Oh, on a related matter (or should I start a new thread?) does anyone know how to remedy a stuck 'stop' button which CAN stop a tape but won't go far enough to release the door?
Anyway, glad you're back up and running :)
