Spectrum+ PSU
edited May 2012 in Wanted
Would even consider a broken one for a reasonable price.:-o
Post edited by napoleonblownaparte on
  • edited May 2012
    IIRC right it's the same as for the rubber key. Any reason that you're looking for an original one?
    If not, any newer PSU with similar specs will do - but you'll have to take extremely care for the polarity.
  • edited May 2012
    Mad Fritz wrote: »
    I just want the original look, if I can find one with a blown rectifier or whatever then I have a modern 1.5A PSU's guts ready to go into the empty case.
    The spectrum in question is to be heavily modified anyway and I was considering using an AT/ATX PSU but that means a lump of grey metal lying around. Are there any more elegant solutions someone can suggest?, I want to add some kind of CF/IDE so a beefier PSU is a must really.
  • edited May 2012
    I should have an empty Spectrum+ PSU case if that would suit - PM me and I will check.
    www.rwapsoftware.co.uk
    www.sellmyretro.com
