door locks ?
just curious if anyone here has fitted any front door ones, or more specifically replaced a night latch.
is there a standard for them ? regardless of maker so I can re-use the same holes? I notice they are either 40mm or 60mm .. from centre of keyhole to door edge.
and if your looking for the knockers thread it's over
I guess I'll find out later :)
Post edited by fog on
DIYNot has some decent info and an excellent forum for answering questions on all sorts of home repairs:
http://www.diynot.com/pages/hs/hs025.php
For years I've used that as my first port of call for all sorts of odd jobs, most recently a dodgy washing machine.
nothing at all, door mechanism just broke.. and the timing.. or maybe because I heard a load of spectrum owners were flying in to heathrow :p
sadly wasn't a "standard" fitting.. so used wood filler to fill in the gap from before, from the previous lock.
I had a friend around anyway doing the work,who is good at such things. because the door is something that I don't want to mess up (stained glass etc)
the old lock , could be "double locked" from the outside.. this one you have to from the inside, so makes it even more secure I guess and obviously they can't just break glass / pull the lever.
