[MIA] Video Spectrum issue 18
Hi folks,
I'm going through a batch of VOC files from Tony (ADJB) ages ago, just I never got around to getting further due to tape signal etc. Some are German and Spanish (SPA2) but I thought I'd raise it here in the hope we can resolve a MIA.
https://dl.dropbox.com/u/15363623/VS18a.zip
https://dl.dropbox.com/u/15363623/VS18b.zip
On Side A, I have a problem with block 4 which should be 40bytes in length, but only seems to capture 27bytes (damaged) (Prog: LABER 1)
Side B, seens to barf after block 9 (Prog: ATERRIZA).
Of course once resolved would be an SPA2 file, unless it's already done ?
Cheers
Andy
Cheers
Andy
Post edited by Andrew Barker on
Laber1 is not part of Video Spectrum issue 18 , this is old record in tape (may be wav come from copy )
Side B have missing basic before cara bytes, and and and .. side b is mission imposible :) Matriz don't must to be in side b
Compilation Contents:
Cesta
Golf
Arana
Tesoro
Indiana Jones
Matriz
Objetivo
Crucigrama
La Nave
Frases
Oruga
Aterriza
Laberinto
This wavs is not enough to close case.
Greets,
Gorski
Many thanks for looking.
Unfortunately, Video Spectrum 18 is not in the queue for the SPA2 next update.
And yes, unfortunately, since as Gorski says they are very strange issues in these wavs anyway. OK for Gorski says about LABER*1, which it seems to come from a prior, lower volume rest of data, and which it sounds fixing a pause between blocks of the real content. For side 2, it is easy to hear two distinct signals are one over the another, so I think it is impossible for extract it :-(.
Cheers,
Jose.
