Blocking adware/popups
Does anyone know of a program I can install (or a setting in IE9) to stop unwanted adverts popping up all over the shop? I'm getting adverts everywhere on every website I visit and its slowing my computer down, I've selected 'block popups' on the IE9 settings but it has made no difference, it's really annoying me.
Any suggestions?
Any suggestions?
Post edited by zx1 on
http://adblockplus.org/
Before IE7, the Google tool bar used to block adverts but it wasn't as efficient as adblock. Also Chrome (and I guess Opera) has better blocking abilities.
An' you know what they said?
Well, some of it was true!
I have decided IE is a load of smelly jobbies!:grin:
I also keep an upto date Spybot, search and destroy (I updated and ran it yesterday and all was clear) and that will block alot of dodgy stuff quietly in the background. Try installing that and imunizing. It's the first thing I did when I got this laptop ;-)
Chrome seems faster that IE anyway so i'll stick to that for the moment.
Blimey, that's a blast from the past. Memories of Windows ME and dialup internet flooding back now... :)
Somthing else to bear in mind: If you're found even one piece of malware on your system, you should be very wary because it's not uncommon for so-called "droppers" to lurk undetected, that is, pieces of well-disguised malware that exist solely to download more malware. Some droppers are by design very difficult to detect, and may continue to reinfect your "clean" machine, over and over again. Whenever I find anything at all, I've got to say that I nuke the system from orbit and reinstall. It's the only way to be sure.
Anyone who finds themselves fixing machines for people on a fairly regular basis would be well advised to create unattended install discs. That way you just put the CD in the b0rked PC, wait a couple of minutes to enter the license key off the CoA, then go and do something else for an hour or so while it installs windows, firefox and MSSE and all the updates by itself :D
Only if they don't have their own PXE server! :p
Norton is a nightmare, i used it back in 2005 and it was so bad it blocked me from everything on my PC as it saw me as a threat!
Uninstalling it was a real headache too, i started using AVG for a few years which was a lot better.
They've improved Norton quite alot over the last couple of years. It's nowhere near the system.hog that it used to be, it's simple to use, keeps itself upto date and I've had no issues with viruses getting in through a "back door". I quite like it now.
On the other hand, the one time it did play up a stopped working, I ended up having to format my drive and start again. But, some of that was my own fault anyway as I turned my laptop off during an update and Windows wouldn't start again!
