Spectrum+ Question
Just bought an "as is" Spectrum+ from eBay. It has "upgraded" stamped in red on the underside on the expansion port. Does this mean someone has upgraded their old rubber key model?
Upon plugging it in, not all the keys work. There seems to be a group not working in the lower half of the keyboard - b, n, m etc. plus a couple of others.
Also the " key does a 'P' and the ; does an 'O'. Does this sound like a membrane problem? Has it not been upgraded properly?
Any ideas?
Any ideas?
Post edited by kev1049 on
with regard to loading, instead of using the P to do the " on the keyboard for load "" , look on the bottom row and you should see a " key that you can use, hopefully
QAOPM were the most used keys on my spectrum , and others I guess :)
you can buy new membranes.. RWAP sells em for a start.
There are two ribbon 'tails' that come from the membrane down to the PCB - the one that has 8 lines on it is broken somewhere. If you're lucky, it'll be right at the end that plugs into the PCB - you can trim 5 or 10 mils of the end of the ribbin and still plug it in... If it's higher up, then I'm afraid it's new membrane time.
Original Connection Insert and connectors on motherboard
New RWAP keyboard membrane with inserts from old membrane
I now have a 48k rubber key model and the Spectrum+. Hmmm someone's selling a +2 on eBay....
Congratulations!
Ace! Glad I could help :)
