big size heat shrink ?
fogfog
edited July 2013 in Chit chat
just curious if any of you use heat shrink, but I need sizes that are bigger than the normal pencil type width. roughly when shrunken to cover a db9 (aka joystick type) connector... well the outer bit.
where to get it, as the usual places only stock the small sized stuff. I found one place , but it's a wait to get the things.
I was thinking of using insulating tape perhaps, but would prefer something like heat shrink or similar.
Post edited by fog on
