The orientation is printed on the silkscreen of the board but I just wanted to be sure due to another transistor (TR4 I think) having to be fitted the other way round on a 4S if you replaced it
Ive compared the two transistors, the original ones C945 and the ordered ones BC548B and theres a bit of a difference in various values, are these going to be ok?
I'm more-or-less certain the transistors I suggested will work for all NPN transistors in the 16/48K Spectrums, apart from use as TR4 or TR7. The pin-out may not be the same as the originals - I can't remember, you'll have to check datasheets.
Had a good look and it appears the orientation is the same, the EBC positioning on both transistors is the same so common sense that they fit the same. Should be here tomorrow so ill fit and see.
Btw, replacing R53 (300ohm) resisistor with an 82ohm, would that help with the black and white (sometimes colour) problem I have with this board and the 2+v Im getting on the video in?
schombi.de/my-retro-collection.html"
