Joysticks for Spectrum +2?
I have a +2a, with a joystick that came with it. Interface II compatibel fo course, the ususal. The yostick itself is a bit of a pain, it's overly resistant, making it a fight with it playing each game. I generally prefer keyboard control, but I find that uncomfortable too, due to the height of the keyboard from the table.
Anyway, its the older games that don;t support Interface II that are the real problem, such as Atic Atac. I just don't get on with Ultimate's awkward keyboard controls layout.
So what is the best solution. Which is the most widely compatible, Kempston or Cursor? And is there a way to attach them to my model of Spectrum? Thanks.
Post edited by Retro_eido on
Most of the ones that stood up at the back, the lower row of legs on the connector can often be persuaded to bend a bit (the edge of a steel ruler might help) to allow the interface to lean back a bit to fit the bigger cases of the later Spectrums.
Any sort of keypress-based interface (cursor or IF2) won't work with a +2A anyway.
Also, you'll need a normal joystick. The ports on the +2 and later machines are deliberately wired differently, and only the official Amstrad/Sinclair joysticks (or the Cheetah ones with two plugs, one black and one grey) would work.
