no color zx spectrum 48k (rubber) composite mod
I have a problem, I just got my 48k speccy and I am waiting for my keyboard mebrane to arrive, meanwhile I did the composite mod and on startup before the "1982 Sinclair Research Ltd" it doesn't show any colours (like the red stripes going down) its all in black and white, but when i move around the composite plug, i get color on startup...
Post edited by duro00611 on
Best thing to do if you don't have any other means to diagnose is to get the membrane replaced, then write a short program to display some coloured text. You can then wiggle the lead to see whether or not the problem's related to the physical connection then.
www.rwapsoftware.co.uk
www.sellmyretro.com
Fingers crossed there's no damage done.
now i dont get output of any kind...
So that means the problem should be down to the video circuit.....
Any more ideas?
www.sellmyretro.com
www.sellmyretro.com
but still no color :/
aand my power socket is loose, it loses contact when i move arround the plug
At least it now looks like all you need is a new power socket - I may have some in stock, otherwise dataserve-retro.co.uk has some...
www.sellmyretro.com
If in doubt whether there is a poor contact in the existing power socket, renew it.
