Silly question I know..
Just started checking my old computers and started with the ac/dc power adaptors.
The 9 volt output is showing 12 to 13 volts
The 12 volt output is showing 13 to 14 volts
So are they ok or do I need new ones ?
Thanks
Thanks
Post edited by woollymammoth on
/Pedro
Edit Yes they are the originals
AC voltage and the rectified voltage in this type of PSU is normally measured as RMS voltage (because the power in a resistor at this voltage is equivalent to the same level of power from a battery) not the peak-to-peak voltage, which is the top and bottom of a mains AC sine wave.
In addition, because the transformer is not supplying the normal load current, it's output will be between 10% to 20% higher than it's rated voltage output.
Is it safe? If the PSU's are original, and the output voltage is 14V or less off load, it should be. If you have a 12V 5W or a 10W car / motorcycle lamp, connect it to the PSU output and if the voltage is now 11.9V or less, it is safe :-).
AL
