SATA Solid State Hard Drive Help Needed
Hi. I have an old PC with an SATA hard drive in it, which I would like to replace with a solid state hard drive. I do not know much about them, so do I need to look for anything in particular when searching for solid state hard drives on eBay?
Thanks for your help.
Post edited by mrmessy on
Having said that, see what SATA version your motherboard supports and get that - remembering that SATA is backwards compatible. Oh, and even though the prices are coming down they're still expensive for a decent sized one (256Gb+). If your just going to use it as your boot drive and have a big platter installed for everything else (like I have) then you'll do just fine.
I've got one of these in both my laptop and desktop and have been delighted with them. Never given me a single seconds trouble.
EDIT: Ah, you did say old PC. It probably depends on how old it is as some don't support the boot sequence IIRC. Check with the motherboard manufacturer.
Yeah, you really don't want to be running XP on an SSD if you want it to live a reasonable life span. You want Windows 7 or above really.
My understanding is that it's not worth fretting over the Flash wearing out*, but using an OS/filesystem without TRIM support will potentially hurt your performance quite a bit.
*obviously it doesn't hurt to minimise unnecessary small writes like disabling saving the file access time on Linux etc. unless you really need it.
There is a better alternative, though. Buy a SSD with a tool that scans the SSD and does the TRIMming for you. My experience is with Samsung models and their Samsung Magician tool works very well for the purpose. I also know for a fact that Intel SSDs have something similar.
/Pedro
True. But even TLC flash has enough reliability for years of normal use. At my work I just replaced a Samsung 840 Evo 128GB SSD that has 52TB of writes on them and Samsung Magician still says it is 100% good. But this one didn't have a life of normal use. It was used on a software build machine 24x7 for a little over a year. :razz:
/Pedro
That's cool to know. Stuff I've read has been inconclusive and erring on the side of avoiding MLC, but real world, real use, benchmarks are hard to find and everyone draws different conclusions :)
I've also found you have to make a note of when any article was written. An article about an SSD technology from 5 years ago is basically irrelevant and full of outdated conclusions and advice :)
What I take away from it all is "trust the firmware, it's pretty smart" and "you aren't running massive database servers, don't worry about it" :)
As mentioned in a previous post, some manufacturers have tools that scan the SSD and "reclaim" deleted space from the OS layer onto the flash cell layer. These normally must be run manually, but maybe some can be scheduled. The Samsung Magician tool only lets me run this function, called "Performance Optimization", from the GUI.
/Pedro
I might be wrong on this, but an SSD in RAID doesn't support trim, so any drive that is designed to work ok in a RAID array should be fine in an OS without trim support.
And I wouldn't worry about ignoring SATA3 drives. I've got a SATA2 controller with a SATA3 drive - no issues. 95% of the performance benefit of an SSD is in random not sequential access, so you don't hit the SATA2 bottleneck.
At least in Windows, certain Intel chipsets (series 7 at least) with Intel RST drivers version 11 and newer support RAID 0 and RAID 1 with TRIM. More advanced Intel chipsets such as the C600 even go as far as supporting RAID 10 with the right driver.
/Pedro
