Testing ZX81 Power Supply
Forgive the total noob question, but I have a ZX81 UK 700 PSU (and no ZX81) - how would I go about testing it is giving the correct output? I have a multimeter, but am not really sure what I'm doing with it (I know - I shouldn't be allowed near electronic stuff). I don't want to sell it on if there is a chance it'll blow up someone's ZX81!
Meanwhile, do you have any 12V lamp bulbs rated at between 1W and 5W? E.g. Car lamps?
I just had a rummage in the back of the car and have found 2 spare bulbs that are both 12V & 5W. I am intrigued as what comes next... :)
I used test leads and a proper lamp holder. But if you don't have these, use stranded wire with the ends stripped off. Wrap the bare ends around the electrical connections (make sure there are no short circuits) and then use tape to hold the wires in place. Wrap the tape as tight as you can.
Your voltages may be slight different, as the Sinclair PSU is an unregulated type.
Do you want any extra words?
I don't have a bulb holder, and looking at the base of the spare bulb it doesn't seem to have 2 contact points that I could tape wires to. I'll take a piccy tomorrow when I have more time. It's frustrating that I am so ill equipped to do this, but I don't mind spending a few quid on some bits as they may came in useful another time.
Or instead use two 10 ohm 5W resistors wired in series.
Alternatively if you have a suitable soldering iron and some solder, you could just solder wires directly to the lamp cap. But it does depend on the type of cap.
Thanks to all for their help with this, especially Mark - are you the guy producing "Mark Fixes Stuff" on YouTube?
[EDIT] I've saved the web page with photos locally, so if you want to remove them from Flickr then that's fine.
Oh, don't worry. I have two Flickr accounts. I tend to leave pictures up for years...
Thanks for filling in the resistor blanks Mark, I didn't have the time to calculate them when I posted.
Mousey, they aren't hard to get:
http://www.ebay.co.uk/itm/Ceramic-Wirewound-Crossover-Resistor-10-Ohm-20-Watt-5-/230791149873?hash=item35bc397931
That's what you are looking for, but you can get them cheaper if you get them from China/Hong Kong and want to wait, or shop around a bit more. You won't need a heat sink, they won't burn your hands off, just don't leave them connected for very long. But if you have the bulb bits to hand may as well use that I guess.
(Basically with both methods all you are doing is putting a load on the unregulated power supply that draws an appropriate amount of current to test it)
