Help with converting a SL3 based wav/csw to tzx
Greets. :)
I was trying to build some high speed tapes using Kobrasofts SL3 > http://www.worldofspectrum.org/infoseekid.cgi?id=0017148
On its highest speed however, I'm unable to get either maketzx or wav2tzx to work, despite hours (!) of trying. :)
Is there a simpler method of determining what I actually need to use / do ?
Thanks! :D
Thanks! :D
Post edited by spider on
Please visit the JetSet Willy & Manic Miner Community
I've spent much time trying various options in both maketzxgui and wav2tzx (command line)
I recall seeing ages ago someone posting extra timing settings for maketzxgui so that you could use (for instance) the Durell loader. I guess all I really need is the 'settings' for the SP3 at speed6.
http://www.wintzx.fr/
No that seems to do the reverse. I have a .wav of the 'high speed' part. :) I made it.
I need to get it converted to .tzx.
I'll probably post some specifics on easy ways of doing this at a near future point if anyone wants to know. :) All the info is here and there but its not always easy (for me at least it was not) to work out exactly what you need to do.
