SD Card Tape Player
Hi, I purchased one of these from China and just wanted to ask a few questions before I break into the packaging.
I see it comes with a power supply. Is this needed when its used in a tape player? If so how do you attach the power lead to a closed cassette deck?
http://www.banggood.com/Vintage-Car-Tape-Cassette-SD-MMC-MP3-Player-Adapter-Kit-With-Remote-Control-p-1012830.html
Thanks
You do not have permission to view polls.
Post edited by jonesypeter on
  • They're cheap mp3 players with cheap batteries. The power supply is needed to recharge the battery... until it fails.
    I've used one of those and it works, but the worst part is that selecting/playing/pausing is not easy (hint: if you press pause on the cassette, the mp3 WON'T stop).
    I was there, too
    An' you know what they said?
    Well, some of it was true!
  • Thanks Zup for the information.
