Joystick interface
I have a grey model 128 +2, I need to know if a jostick interface can be used on this machine as Spectrum only sicks are hard to come by.
Thanks for your time.
Washac:)
Post edited by Anonymous on
  • edited April 2001
    Speccy only sticks!
    It was a major critisism when the machine came out as far as I remember.
    If you can find the pinouts I will probably be fairly easy to make a converter!
  • edited April 2001
    You can use a normal interface2/kempston unit in the back of the +2 as it is virtually the same internally as the black sinclair 128k. A lot of old sticks have the interface built in also for the supplied ports, look out for a extra grey connector icon_wink.gif
  • edited April 2001
    Hi, thanks for the replies.
    Washac:)
  • edited April 2001
    Yup, dug out an Interface and it all works.
    Washac:)
