I am looking for an artist for drawing sprites.
Are you interested? write here.
[Stronghold] [l'Abbaye des Morts] [Stronghold2 WiP (30%) defrosen]
  • Possibly depending on how many and how quickly you want them.
  • Perhaps it would be a good idea to write how many you need and how big they should be ... and what kind of theme.
  • I can do a rather dangerous looking Helicopter UDG
    Or an angry horned demon from Doom
    I struggle with anything bigger than 8*8 though.
  • Thank you for your interest
    I need sprites for a big enough game. And the sprite of the main character and NPCs and monsters.
    Here is the main charaster (prototype)
    he must be improved
    need walk (4 phases) jump(1-2 phase), attack(throw chakram 2-3 (phases)), duck (he hides behind his weapon, weapon are separate object)
    Here is one of the NPC
    game will be colored with nirvana style method.
    sprite size 18w * 2-18h for most objects.
    main theme - demons, curses, witches, magic.
    and a single mocup screen
  • Just out of curiousity Jerri? How come the sprite files are so blurry? Thats rather unusual for such blocky graphics, they usually hold their definition no matter what.
    Also on the main screen your character seems to be more horizontal than vertical, is it meant to be an animal, like a rat perhaps? I'm simply asking because it would make a difference to the designs I come up with, or is that character shown horizontal because it/he's been knocked down in the game?
  • edited January 2020
    its because dropbox
    all pictures still prototype
    Post edited by Jerri on
    OK. Thanks, I wish I could speak Russian! I thought of using Google Translate but it usually makes some pretty comical errors so I decided not to risk it in case what it produced wasnt what I meant.
    Lets see what it does with this...I don't know, it's all cyrillic to me!
    OK. Спасибо, я хотел бы говорить по-русски! Я думал об использовании Google Translate, но он обычно делает несколько довольно комичных ошибок, поэтому я решил не рисковать в случае, если то, что он произвел, было не тем, что я имел в виду.
    OK. Spasibo, ya khotel by govorit' po-russki! YA dumal ob ispol'zovanii Google Translate, no on obychno delayet neskol'ko dovol'no komichnykh oshibok, poetomu ya reshil ne riskovat' v sluchaye, yesli to, chto on proizvel, bylo ne tem, chto ya imel v vidu.
    Post edited by mik3d3nch on
    mik3d3nch wrote: »
    Я не вижу проблем как в использовании русского языка, так и в использовании Google translate.
    I see no problems in using both the Russian language and using Google translate.
    Пишите как вам удобнее.
    Write as you prefer.
