TR-Dos converting problem.
I take a .tap file. Then I use the program tap2trd and convert it. I got a .trd file. With the program Samdisk I'll transfer it to disk. But the converted program did not start in TR-Dos or crashes immediately. I'm using a Beta Disk controller from Technology Research Limited.
What made I wrong?
Micky
  • Trdos after first init shift zx basic in zx ram about 112 bytes, then very low original ramtop in basic loaders must be often higher here.
  • You mean there is not enough ram. Is it possible to shift the basic loaders to higher positions?
    Micky
  • edited May 26
    -Micky wrote: »
    Micky
    It may be possible. But it´s manual work and no automatic. If free space is too low, it may be impossible. You should tell us which tap.-File you try to convert. And where we can download it for having a look at it.
    Post edited by Luzie on
  • It is this one and from here:
    https://www.worldofspectrum.org/infoseekid.cgi?id=0001317
    Micky
    Spectrum ZX 48 Harlequin Revision E, ZX Sprinter 2000, Tr-Dos Beta Disk.
  • edited June 27
    I´ve taken one of those three Tape-Files from WOS and exit into Basic with Multiface. On SpecEmu.
    With 128k Machine Emulation I get a "N: Statement Lost70:1" error when I´m doing an LIST. There is no Line 70. So BASIC/Variable-Area which is saved with BASIC seems to be corrupted.
    With 48k Machine Emulation I get no error when I´m doing an LIST.
    Re-Starting the game with RANDOMIZE USR 41836 starts the game fine.
    I think, even if 128k mentioned on Currys Re-Release Cassette Cover it should be run in 48k mode?
