Textured Scanline Flood Fill for ZX Spectrum 48K
Pity that it's quite hard to contribute code to WoS in a straightforward manner. Recently, I have created a textured/hatched fill M/C routine for the ZX Spectrum 48K. It was for a text/graphic adventure I'm working on. The algorithm is based on John Metcalf's Scanline Floodfill algorithm that I pimped a bit to support textures and color.
Unfortunately, I can't attach a ZIP archive here, so the assembler listing and Sinclair BASIC wrapper must suffice. Have fun!
1 REM Colored Pattern Fill
2 REM (C) 2021 V. Bartheld
3 REM CC BY License
4 REM www.bartheld.net
5 REM Based on an idea of
6 REM John Metcalf
7 REM www.retroprogramming.com/2017/04/zx-spectrum-scanline-flood-fill.html
10 CLEAR 57343: REM Leave some space for shadow screen buffer
20 GO SUB 9000: REM Prep m/c
100 FOR i=1 TO 20
110 LET x=40+RND*176
120 LET y=40+RND*95
130 LET r=10+RND*30
140 CIRCLE x,y,r
200 REM Coordinates to start fill
210 POKE 63694,x: REM x
220 POKE 63695,175-y: REM y
300 REM Location of fill pattern
310 IF RND>0.8 THEN GO TO 370
320 LET o=15624+8*INT(RND*30)
330 REM Character fill
340 POKE 63692,o-256*INT(o/256): REM lower byte
350 POKE 63693,o/256: REM higher byte
360 GO TO 400
370 REM Hatched fill
380 POKE 63692,196: REM lower byte
390 POKE 63693,248: REM higher byte
400 REM color
410 LET c=56+RND*7
420 POKE 63696,c: REM random ink, white paper
500 RANDOMIZE USR 63488
510 NEXT i
520 STOP
9000 PRINT "{AT 10,11}WAIT..."
9010 LET a=63488
9020 READ a$: PRINT "{AT 20,0}";a$
9030 IF a$="" THEN CLS: RETURN
9040 FOR n=1 TO LEN a$ STEP 2
9050 LET s$=a$(n): GO SUB 9100: LET v=16*s: LET s$=a$(n+1): GO SUB 9100: LET v=v+s
9060 POKE a,v: LET a=a+1
9070 NEXT n
9080 GO TO 9020
9100 LET s=0
9110 IF s$(1)>="0" AND s$(1)<="9" THEN LET s=CODE S$(1)-CODE("0")
9120 IF s$(1)>="A" AND s$(1)<="F" THEN LET s=10+CODE S$(1)-CODE("A")
9130 RETURN
9500 DATA "010018C50B2100E0E5545D133600EDB02ACEF8555CCD4BF8E1E50603C5ED5BCC"
9510 DATA "F8CD37F8C110F5E1110040C11AAE1213230D20F810F6C90E08E506001AEEFFA6"
9520 DATA "772310F8E124130D20EFC92EFFE57AE6073C473E010F10FD48477AB7280D15CB"
9530 DATA "00CD99F820F4CB08142828CD99F8282377E57CF6E0677EB077E17C0F0F0FE603"
9540 DATA "F658673AD0F8771CCDB3F81D1DCDB3F81C18D3D17B3C20B6C97BE6F81F371F1F"
9550 DATA "6FABE6F8AB677DAAE607AA0F0F0F6F78B6BEC9CB217BFEC0D0CD9AF8C80CCB51"
9560 DATA "C0E1D5E9AA55AA55AA55AA55C4F880603A"
9570 DATA ""
    %include "compat.asm"
    %outfile "patternfill.bin"
SCREEN: EQU 4000h   ; 16384d
    ORG E000h       ; start of "shadow screen" (57344d)
SHADOW:
    ORG E000h+1800h ; start of main program (63488d)
START:
    ; clear shadow screen area first
    LD BC,1800h
    PUSH BC
    DEC BC
    LD HL,SHADOW
    PUSH HL
    LD D,H
    LD E,L
    INC DE
    LD (HL),0
    LDIR
    ; flood fill main screen starting from coordinate in COORD while caching only the filled portions in shadow screen area
    LD HL,(COORD) ; L=x-coordinate, H=y-coordinate
    LD D,L        ; swap
    LD E,H
    CALL FILL     ; call modified flood fill by John Metcalf
    ; create pattern in shadow screen area, spanning all 3 thirds of the screen
    POP HL
    PUSH HL
    LD B,3        ; screen is divided in 3 consecutive thirds
THIRD:
    PUSH BC
    LD DE,(PATT)  ; pattern/udg start address (8 bytes)
    CALL PATFILL  ; fill one third of the screen with pattern
    POP BC
    DJNZ THIRD    ; 3 times
    ; write back shadow area to main screen
    POP HL
    LD DE,SCREEN
    POP BC
WRBACK:
    LD A,(DE)
    XOR (HL)
    LD (DE),A
    INC DE
    INC HL
    DEC C
    JR NZ,WRBACK
    DJNZ WRBACK
    RET
; The ZX Spectrum's screen layout is a bit weird:
; The first 3 bits of the address are always 010.
; The next 2 bits denote in which third of the screen the byte is.
; the last 3 bits denote in which of the 8 scan lines within a third
; the byte is located. There are 24 discrete values.
; So if HL contains the first scan line of a screen position, we just need
; to increment H (add 256) to get to the next scan line.
; If we increment L, we advance one byte (8 pixel positions) to the left.
; %010 00 000 is the top left position in the 1st third of the screen.
; %010 01 000 is the top left position in the 2nd third of the screen.
; %010 10 000 is the top left position in the 3rd third of the screen.
; %010 tt sss cccccccc
; we expect HL pointing to a screen buffer containing a mask of black pixels
; those pixels are then replaced by a pattern starting at DE
; if we XOR back this screen buffer to the real screen that has been already filled solid black
; the result is a pattern fill
PATFILL:
    LD C,8      ; each character has 8 rows
NXTLIN:
    PUSH HL
    LD B,0      ; 8 scan lines with 256 pixels divided into 32 columns (8*256/8)
ROW:
    LD A,(DE)   ; get pattern
    XOR FFh     ; invert it
    AND (HL)    ; merge with screen contents
    LD (HL),A   ; and write back
    INC HL      ; next column
    DJNZ ROW    ; next row
    POP HL
    INC H       ; advance to next scan line of screen
    INC DE      ; advance to next line of pattern
    DEC C
    JR NZ,NXTLIN
    RET
; scanline fill by John Metcalf
; call with D=x-coord, E=y-coord
; set end marker
FILL:
  LD L,255
  PUSH HL
; calculate bit position of pixel
NEXTRUN:
  LD A,D
  AND 7   ; retain pixel position within x-coordinate in D
  INC A   ; must increment by one since x=0 means rotating one time to the right, to get from %00000001 -> %100000000
  LD B,A
  LD A,1
BITPOS:
  RRCA    ; rotate %00000001 right across 8 bit (no carry)
  DJNZ BITPOS ; for x%8+1 times
  LD C,B
  LD B,A
; move left until hitting a set pixel or the screen edge
SEEKLEFT:
  LD A,D
  OR A
  JR Z,GORIGHT    ; D is zero already, we have reached the left border of the screen. Skip going any further.
  DEC D
  RLC B
  CALL SCRPOS
  JR NZ,SEEKLEFT
; move right until hitting a set pixel or the screen edge,
; setting pixels as we go. Check rows above and below and
; save their coordinates to fill later if necessary
SEEKRIGHT:
  RRC B
  INC D
  JR Z,RIGHTEDGE  ; D has just overflown from 255 -> 0, so we crossed the right edge of the screen. skip going any further.
GORIGHT:
  CALL SCRPOS     ; Test screen position
  JR Z,RIGHTEDGE
  ; pixel is blank: fill it
  LD (HL),A       ; plot pixel on "real" screen
  ; now get address of shadow screen
  PUSH HL
  LD A,H
  OR %11100000    ; calculate address on "shadow screen" %010 tt sss cccccccc -> %111 tt sss cccccccc
  LD H,A
  LD A,(HL)       ; get the byte there
  OR B            ; fill pixel
  POP HL
  ; deal with color attribute now (stolen from L0BDB/PO-ATTR in the ZX Spectrum ROM)
  LD A,H
  RRCA            ; shift
  RRCA            ; bits 3 and 4
  RRCA            ; to right
  AND 03h         ; range is now 0-2
  OR 58h          ; form correct high byte for third of screen
  LD H,A          ; HL is now correct
  LD A,(ATTR)     ; get color attribute
  LD (HL),A       ; and set it
  INC E           ; increase y-coordinate to look at row below current one
  CALL CHECKADJ   ; check limits and if there's a pixel to be filled
  DEC E           ; revert
  DEC E           ; decrease y-coordinate to look at row above current one
  INC E           ; revert
  JR SEEKRIGHT
; check to see if there's another row waiting to be filled
RIGHTEDGE:
  POP DE
  LD A,E
  INC A     ; if 255 was on the stack: A=0
  JR NZ,NEXTRUN
  RET
; calculate the pixel address of coordinate in DE (D=x, E=y) and whether or not it's set
; this is similar to PIXEL-ADD (L22AA) in the ZX Spectrum ROM with the exception,
; that the coordinates are in DE instead of BC and the bit mask (in B) is already
; prerotated. If the Z flag is not set, the pixel at DE is blank (=needs to be filled)
SCRPOS:
  LD A,E
SCRPOS1:
  AND %11111000
  RRA
  SCF
  RRA
  RRA
  LD L,A
  XOR E
  AND %11111000
  XOR E
  LD H,A
  LD A,L
  XOR D
  AND %00000111
  XOR D
  RRCA
  RRCA
  RRCA
  LD L,A
  LD A,B
  OR (HL)
  CP (HL)   ; if content of A did not change after the OR, the pixel was already set. E. g. testing for bit 4: 00010000 OR 11111111 == 11111111
  RET
; check and save the coordinates of an adjacent row
CHECKADJ:
  SLA C
  LD A,E
  CP 192        ; did we arrive at the bottom of the screen (y=192)?
  RET NC        ; done.
  CALL SCRPOS1  ; skip useless LD A,E instruction
  RET Z
  INC C
  BIT 2,C
  RET NZ
  POP HL
  PUSH DE
  JP (HL)
PATT_D:
    ; checkerboard pattern
    DB    %10101010
    DB    %01010101
    DB    %10101010
    DB    %01010101
    DB    %10101010
    DB    %01010101
    DB    %10101010
    DB    %01010101
PATT: DW PATT_D ; point to your fill pattern here
; PATT: DW 3D08h ; can also be a target within the ZX Spectrum's charset, e.g. 3D00h+8h to fill with '!'
COORD:          ; start coordinates for fill
    DB 80h      ; x
    DB 60h      ; y
ATTR:
    DB %00111010  ; the bits are: Flash|Bright|Paper(Green|Red|Blue)|Ink(Green|Red|Blue)
ENDPRG:
Thanked by 1p13z
  • A bit of standard optimization, if you will. This snippet:
      RRCA            ; shift
      RRCA            ; bits 3 and 4
      RRCA            ; to right
    could be replaced with
    	or $87
    	rra
    	rra
    	srl a
    Saves one byte and three T states.
    A few Spectrum game fixes.
  • edited February 2021
    Nice work :)
    It is possible to make it much faster and use much less memory. The main fill routine is slower than it has to be because it moves one pixel at a time and it computes a screen address for every pixel visited. It also uses a lot more memory than it has to because it's a depth first recursion so you end up with a lot of dead ends on the stack. It says it uses less memory and that's because it immediately visits the left and right directions rather than recursing to them. But that can still be a lot of memory -- have you checked that against open fills of the screen?
    Here's a different one:
    https://www.worldofspectrum.org//pub/sinclair/utils/FastWell-BehavedPatternFloodFillA.tap.zip
    Source code:
    https://github.com/z88dk/z88dk/blob/master/libsrc/_DEVELOPMENT/arch/zx/graphics/z80/asm_zx_pattern_fill.asm#L57
    The fill operates on whole screen bytes at a time rather than individual pixels and it uses screen addresses rather than pixel coordinates so screen addresses don't have to be calculated at every step.
    You can imagine a starting point to fill from "00010000" into a screen byte "11000100". ANDing the incoming pixel with the complement of the screen byte shows where the fill can grow from "00010000". Then you wiggle this byte left and right one bit position until ANDing with the complement of the screen byte doesn't change. That's your fill byte "00111000". This fill byte can be written and then you can move up, down, left or right with it. When moving up or down, the starting fill byte will be the same. Moving left only happens if bit 7 is set and moving right only happens if bit 0 is set. The starting fill bytes will be "00000001" and "10000000" respectively. The current screen address is modified to move up,down,left,right by byte amounts which is much faster than calculating from pixel coordinates.
    To deal with the memory problem, the recursion is breadth first rather than depth first. Instead of just pushing pixels to visit later in any old order, the order of visiting pixels follows a diamond shape growing from the start point so that pixels visited later are always on the perimeter of the growing pattern fill. Stack usage is proportional to perimeter rather than area.
    A pattern fill using this last method can be completed on any screen with about 900 bytes of stack use whereas the one you're doing requires a second display file (6912 bytes) plus stack use for the recursion (~10Kish in bad cases?). The stack use is managed as a circular queue whose size is controlled by the caller so you can try to use less memory and the fill will bail if it runs out by patterning and exiting.
    Post edited by Alcoholics Anonymous on
  • If you want to attach a ZIP file, then you'll have to put the file somewhere online, like mega, dropbox, google drive. Then post the link here instead.
    Although I like you posting source code too. Thanks.
  • I've had a play with this and created a zmakebas zasm assembler version available here
    I also included the "optimisation" suggested by @Ast_A_Moore above as conditional assembly so you can
    switch it on and off and compare results easily :)
    It's definitely a fast and flexible fill routine at the expense of being a bit memory hungry (due to the alternate
    $1800 byte display file)
    Regards,
    Derek.
    1985: ZX Spectrum+ 48K Interface 1 ZX81 16KB ASZMIC/SP ROM Philips 12" B/W TV Epson Dot Matrix Printer ZX Printer Now: 2021 M1 iMac 4.5K 24" screen 8 CPU cores 8GB RAM macOS 14.4.1 1TB SSD Drive Ext 1TB SSD Drive Ext 5TB USB 3.1 Hard Disk iPad R7 32GB iPadOS 17.4.1 iPhone SE R2 64GB iOS 17.4.1 Apple TV Gen 2
  • Sorry for being so late. Yes..
    Crisis wrote: »
    Hi Volker, i dont know what the link should do, but it recycles this tread
    so, this is the correct one ?
    http://www.retroprogramming.com/2017/04/zx-spectrum-scanline-flood-fill.html
    is the correct link.
  • Nice work :)
    It is possible to make it much faster and use much less memory. The main fill routine is slower than it has to be because it moves one pixel at a time [...]
    Source code:
    WOW! Now that's clever. Seems that I finally have to write my "Hobbit" clone that accepts Inkscape .svg graphics as an input...
