Help Needed - ZX 32 Problem
edited July 2005 in Emulators
Hi.
I have a problem with the ZX32 Emulator. When I load a zipped .tzx game which consists of more than 1 file in the archive, the ZX32 emulator loads only the first file (the program file) and doesn't load the rest (data blocks). For example, I tried to load the game X-Out, and the emulator loaded the program file. A message appeared on the screen "Rewind to side B and play the tape" but the emulator doesn't "play side B".
Please help me solve that problem or if there's another emulator that could load that kind of games please tell me!
Thanks in advance.
Post edited by dosh on
  • edited July 2005
    Patient: Doctor, Doctor, it hurts when I do <mumble>.
    Doctor: Well, don't do <mumble> then.
    Substitute "Use a zipped tzx" for <mumble> and I think I see a solution to this problem. I find it hard to believe you actually need the disk space.
    [ This Message was edited by: Philip Kendall on 2005-07-10 10:48 ]
  • edited July 2005
    Try SPIn or Spectaculator...
  • edited July 2005
    BTW. Welcome to the forums :)
  • edited July 2005
    I'd unzip the files if I were you.
    Pressing SHIFT when double clicking the file in ZX32's Open File window won't reset the emulated machine
  • edited July 2005
    I tried SPIN and Spectaculator but they run very slow on my machine and they crash. I don't know why...
  • edited July 2005
    I unzipped files and tried loading them but it was the same problem... But I didn't try pressing SHIFT while Opening the second file. I'll try it today. Thank you. I hope it will work!
  • edited July 2005
    Thank you!
    btw Pardon my english. I'm Russian...
  • edited July 2005
    Don't worry about your english - you write more coherently than half the British people on here :)
    Marko
  • edited July 2005
    Naq sne zber pbureragyl guna gur Fpbgf va Zbgurejryy.
  • edited July 2005
    Bless you!
    (edit: Lrg rira zber fb guna gur ratyvfu va Fphagubecr!)
    Marko
    [ This Message was edited by: Marko on 2005-07-11 20:29 ]
  • edited July 2005
    Ok, enough!
  • edited July 2005
    Thank you, zeropolis79! I pressed SHIFT when opening the data blocks and it worked! I'm very glad, you know.
    It's a pity I don't have much time for playing these days... :)
  • edited July 2005
    You're welcome.
    I thought I was the only one to still use ZX32 these days (although I use Spin sometimes)
