Well what connections are you missing? they are pretty standard parts. TV cable, AC adapter (you can use a generic one with the right voltage/ampage) and the joysticks (Ebay or junk shop).
I seem to have two types of AC adapters that plugs into anything. My game player's suppose to Have an original AC power adapter and I'm missing the TV/GAME SWITCH Box.
Well, the AC adapter plugs in the middle of the back (if its the old woody Atari), look for the hole, make sure your using the right adapter if you have 2. Do a google for the Voltage/ampage of the 2600 and then check which one it is.
As far as the TV switchbox goes, you can pick them up at Tandy/Rado Shack, Ebay etc for a $4 or similar depending on your country.
It is a 2600. I saw a Game/TV switch in EBAY, about 1.99 yet My wife complained about the money order fee. So maybe I'll check Radio Shack or other local elecronics stores
Yep they have them in radio shack, and biglots if there is one of them near you.
Check this page for Adapter info.
http://www.best-electronics-ca.com/2600_help.htm
[ This Message was edited by: beanz on 2005-11-07 22:01 ]
XL, XE, VCS console etc etc?
good point, I was automatically assuming a 2600 hehe.
Skarpo
Are you in the USA?
and if it's tv leads it's NTSC not PAL
