Competition Pro Joystick Problems
edited November 2005 in Games
Hi!
I've recently got back into the World of Spectrum - I downloaded an emulator and found little trouble in running games then playing them with the keyboard.
I thought it would be a great idea to get an old-style joystick so I bought a Speed Link Competition Pro - only trouble is, I can't get any of the emulated games to recognise it!
I wonder if anyone can tell me if I'm missing something obvious, or can suggest any other way of getting it to work?!
Any help gratefully received!
Post edited by Steve on
  • edited November 2005
    This is weird. Normally your PC should recognice it by itself, and then there shouldn't be any problems. I connected it, and it worked automatically on Spectaculator, RealSpectrum, MAME and a new Amstrad Emulator I've tested.
    Does it show up in the Gaming Controls on the control panel?
    As the joystick came without any instructions or program disk whatsoever, I had a good search around on the net again after I posted here to see what else I could find on the topic.
    I happened across another article/review and found that there were a load of setting changes I had to make, and now the joystick works!
    So, problem solved!
    Thanks for your reply!
    Good for you it works.
    What do you think of it, or is that to early to answer?
    I like it, but I do think it clicks harder, and is not as precise as the original. Don't know how to explain it, but I still prefer the originals :)
    You could always get one of those C64s that plug into the telly, gut the C64 and keep the joystick. You would need to add a lead to plug it in though.
    I rather buy one of the originals on Ebay. Its just that I haven't found a way to plug them to the USB port yet, so I can only use them on my old PC :(
    I had a load of Competition Pro joysticks when they first came out.
    This new one seems a bit flimsier than I remember them being before - the action seems longer and the buttons feel as if they may break very soon!
    The best joysticks I used to buy were (from memory) the Powerplay Cruiser (blue/white/red or green/pink/yellow - I seem to remember you could adjust the length of action) and the one that used to look like the CP but had yellow square buttons (Zipstick?) - are either of these still made I wonder?
    I......I haven't found a way to plug them to the USB port yet, so I can only use them on my old PC :(
    Heres How to Make a gizmo to convert Atari joysticks to USB:--
    http://www.vilminko.net/henri/projview.php?id=19&lang=en
    _________________
    I did not Tape-to-Tape Games as a Kid - your honour !!
    [ This Message was edited by: murtceps on 2005-11-11 23:48 ]
    [ This Message was edited by: murtceps on 2005-11-11 23:50 ]
    Or buy one from Atari age
