Mag scans in the archive
I know that if you change the page number of the scan you'll get the next page, but a lot of the time with multi-page reviews only the first page is linked to in the archive.
See Firefly as an example.
Any chance of this being fixed in future? I think it's been like this... forever.
Post edited by Vertigo on
I have all that info, and writing the script would be easy, it's just getting around to it that is the problem :)
The fault for that actually lies with the publishers. Keeping the cover as page 1, there were often 2 advert pages that were not counted in the page numbering, so the following page (with actual content) had page number 2, while it was the 4th page, and so on. We wanted to maintain the real page number in the filename and thus had to revert to naming the two discounted advert pages 1b and 1c (where Mort uses 1a, I use 1).
I use the same trick for the other magazines (I mean the ones not scanned by Mort).
Thou asketh and thou receiveth.
Let me know if something doesn't work!
This of course also makes it very easy to read all of the magazines by page too, which is also greatly appreciated and will waste plenty more of my deadline time, but I'm sure we'll all be careful not to abuse the system.
Thanks again.
C&VG, Crash,
Your Sinclair, Your Spectrum, Sinclair User, and so on.
To be honest, I'm not particularly looking forward to adding several more forms at every location some info might be incorrect. At the bottom of each Infoseek query is a mail link, which should do the trick. We tend to solve reported errors quickly.
